Allow users or groups to bypass directory traverse checking
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
If you want a user to be able traverse all the directories in the path to a file even if the user does not have permissions on a traversed directory, you can add the SeChangeNotifyPrivilege
privilege to local SMB users or groups on storage virtual machines (SVMs). By default, users are able to bypass directory traverse checking.
A SMB server must be exist on the SVM.
The local users and groups SMB server option must be enabled.
The local or domain user or group to which the
privilege will be added must already exist.
When adding privileges to a domain user or group, ONTAP might validate the domain user or group by contacting the domain controller. The command might fail if ONTAP cannot contact the domain controller.
Enable bypass traverse checking by adding the
privilege to a local or domain user or group:vserver cifs users-and-groups privilege add-privilege -vserver vserver_name -user-or-group-name name -privileges SeChangeNotifyPrivilege
The value for the
-user-or-group-name
parameter is a local user or group, or a domain user or group. -
Verify that the specified user or group has bypass traverse checking enabled:
vserver cifs users-and-groups privilege show -vserver vserver_name ‑user-or-group-name name
The following command enables users that belong to the “EXAMPLE\eng” group to bypass directory traverse checking by adding the SeChangeNotifyPrivilege
privilege to the group:
cluster1::> vserver cifs users-and-groups privilege add-privilege -vserver vs1 -user-or-group-name EXAMPLE\eng -privileges SeChangeNotifyPrivilege cluster1::> vserver cifs users-and-groups privilege show -vserver vs1 Vserver User or Group Name Privileges --------- --------------------- --------------- vs1 EXAMPLE\eng SeChangeNotifyPrivilege
Disallowing users or groups from bypassing directory traverse checking
