Commands for managing NTFS SACL access control entries
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
There are specific ONTAP commands for managing SACL access control entries (ACEs). You can add ACEs to NTFS SACLs at any time. You can also manage existing NTFS SACLs by modifying, deleting, and displaying information about ACEs in SACLs.
If you want to… | Use this command… |
Create ACEs and add them to NTFS SACLs |
Modify existing ACEs in NTFS SACLs |
Display information about existing ACEs in NTFS SACLs |
Remove existing ACEs from NTFS SACLs |
See the man pages for the vserver security file-directory ntfs sacl
commands for more information.
