Configure the grant UNIX group permission to SMB users
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can configure this option to grant group permissions to access files or directories even if the incoming SMB user is not the owner of the file.
Set the privilege level to advanced:
set -privilege advanced
Configure the grant UNIX group permission as appropriate:
If you want to Enter the command Enable the access to the files or directories to get group permissions even if the user is not the owner of the file
vserver cifs options modify –grant-unix-group-perms-to-others true
Disable the access to the files or directories to get group permissions even if the user is not the owner of the file
vserver cifs options modify –grant-unix-group-perms-to-others false
Verify that the option is set to the desired value:
vserver cifs options show –fields grant-unix-group-perms-to-others
Return to the admin privilege level:
set -privilege admin
