Configure roaming profiles
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
If you want to automatically make a user's profile available when that user logs on to any computer on the network, you can configure roaming profiles through the Active Directory Users and Computers MMC snap-in. If you are configuring roaming profiles on Windows Server, you can use the Active Directory Administration Center.
On the Windows server, open the Active Directory Users and Computers MMC (or the Active Directory Administration Center on Windows servers).
Locate the user for which you want to configure a roaming profile.
Right-click the user and click Properties.
On the Profile tab, enter the profile path to the share where you want to store the user's roaming profile, followed by
%username%
.For example, a profile path might be the following:
\\vs1.example.com\profiles\%username%
. The first time a user logs in,%username%
is replaced with the user's name.In the path
,profiles
is the share name of a share on storage virtual machine (SVM) vs1 that has Full Control rights for Everyone. -
Click OK.
