Manage domain controller discovery
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Beginning with ONTAP 9.3, you can modify the default process by which domain controllers (DCs) are discovered. This enables you to limit discovery to your site or to a pool of preferred DCs, which can lead to performance improvements depending on the environment.
By default, the dynamic discovery process discovers all available DCs, including any preferred DCs, all DCs in the local site, and all remote DCs. This configuration can lead to latency in authentication and accessing shares in certain environments. If you have already determined the pool of DCs that you want to use, or if the remote DCs are inadequate or inaccessible, you can change the discovery method.
In ONTAP 9.3 and later releases, the discovery-mode
parameter of the cifs domain discovered-servers
command enables you to select one of the following discovery options:
All DCs in the domain are discovered.
Only DCs in the local site are discovered.
The
default-site
parameter for the SMB server can be defined to use this mode with LIFs that are not assigned to a site in sites-and-services. -
Server discovery is not performed, the SMB server configuration depends only on preferred DCs.
To use this mode, you must first define the preferred DCs for the SMB server.
You must be at the advanced privilege level.
Specify the desired discovery option:
vserver cifs domain discovered-servers discovery-mode modify -vserver vserver_name -mode {all|site|none}
Options for the
mode
parameter:-
all
Discover all available DCs (default).
site
Limit DC discovery to your site.
none
Use only preferred DCs and not perform discovery.
