Create data volumes without specifying junction points
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can create a data volume without specifying a junction point. The resultant volume is not automatically mounted, and is not available to configure for NAS access. You must mount the volume before you can configure SMB shares or NFS exports for that volume.
The aggregate in which you want to create the volume must already exist.
Create the volume without a junction point by using the following command:
volume create -vserver vserver_name -volume volume_name -aggregate aggregate_name -size {integer[KB|MB|GB|TB|PB]} -security-style {ntfs|unix|mixed}
Specifying a volume security style is optional. If you do not specify a security style, ONTAP creates the volume with the same security style that is applied to the root volume of the storage virtual machine (SVM). However, the root volume's security style might not be the security style you want applied to the data volume. The recommendation is to specify the security style when you create the volume to minimize difficult-to-troubleshoot file-access issues.
There are many optional parameters that you can use to customize a data volume. To learn more about them, see the man pages for the
volume create
command. -
Verify that the volume was created without a junction point:
volume show -vserver vserver_name -volume volume_name -junction
The following example creates a volume named “sales” located on SVM vs1 that is not mounted at a junction point:
cluster1::> volume create -vserver vs1 -volume sales -aggregate aggr3 -size 20GB [Job 3406] Job succeeded: Successful cluster1::> volume show -vserver vs1 -junction Junction Junction Vserver Volume Active Junction Path Path Source --------- ---------- -------- --------------- ----------- vs1 data true /data RW_volume vs1 home4 true /eng/home RW_volume vs1 vs1_root - / - vs1 sales - - -
