Modify local groups
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
You can modify existing local groups by changing the description for an existing local group or by renaming the group.
If you want to… | Use the command… |
Modify the local group description |
Rename the local group |
The following example renames the local group “CIFS_SERVER\engineering” to “CIFS_SERVER\engineering_new”:
cluster1::> vserver cifs users-and-groups local-group rename -vserver vs1 -group-name CIFS_SERVER\engineering -new-group-name CIFS_SERVER\engineering_new
The following example modifies the description of the local group “CIFS_SERVER\engineering”:
cluster1::> vserver cifs users-and-groups local-group modify -vserver vs1 -group-name CIFS_SERVER\engineering -description "New Description"
