Monitor SMB encryption statistics
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can monitor SMB encryption statistics and determine which established sessions and share connections are encrypted and which are not.
The statistics
command at the advanced privilege level provides the following counters, which you can use to monitor the number of encrypted SMB sessions and share connections:
Counter name | Descriptions |
Gives the number of encrypted SMB 3.0 sessions |
Gives the number of encrypted shares on which a tree connect has happened |
Gives the number of session setups rejected due to a lack of client encryption capability |
Gives the number of share mappings rejected due to a lack of client encryption capability |
These counters are available with the following statistics objects:
cifs
enables you to monitor SMB encryption for all SMB 3.0 sessions.SMB 3.0 statistics are included in the output for the
cifs
object. If you want to compare the number of encrypted sessions to the total number of sessions, you can compare output for theencrypted_sessions
counter with the output for theestablished_sessions
counter.If you want to compare the number of encrypted share connections to the total number of share connections, you can compare output for the
encrypted_share_connections
counter with the output for theconnected_shares
counter. -
rejected_unencrypted_sessions
provides the number of times an attempt has been made to establish an SMB session that requires encryption from a client that does not support SMB encryption. -
rejected_unencrypted_shares
provides the number of times an attempt has been made to connect to an SMB share that requires encryption from a client that does not support SMB encryption.
You must start a statistics sample collection before you can view the resultant data. You can view data from the sample if you do not stop the data collection. Stopping data collection gives you a fixed sample. Not stopping data collection gives you the ability to get updated data that you can use to compare against previous queries. The comparison can help you identify trends.
Set the privilege level to advanced:
set -privilege advanced
Start a data collection:
statistics start -object {cifs|smb1|smb2} -instance instance -sample-id sample_ID [-node node_name]
If you do not specify the
-sample-id
parameter, the command generates a sample identifier for you and defines this sample as the default sample for the CLI session. The value for-sample-id
is a text string. If you run this command during the same CLI session and do not specify the-sample-id
parameter, the command overwrites the previous default sample.You can optionally specify the node on which you want to collect statistics. If you do not specify the node, the sample collects statistics for all nodes in the cluster.
Use the
statistics stop
command to stop collecting data for the sample. -
View SMB encryption statistics:
If you want to view information for… Enter… Encrypted sessions
show -sample-id sample_ID -counter encrypted_sessions|node_name [-node node_name]
Encrypted sessions and established sessions
show -sample-id sample_ID -counter encrypted_sessions|established_sessions|node_name [-node node_name]
Encrypted share connections
show -sample-id sample_ID -counter encrypted_share_connections|node_name [-node node_name]
Encrypted share connections and connected shares
show -sample-id sample_ID -counter encrypted_share_connections|connected_shares|node_name [-node node_name]
Rejected unencrypted sessions
show -sample-id sample_ID -counter rejected_unencrypted_sessions|node_name [-node node_name]
Rejected unencrypted share connections
show -sample-id sample_ID -counter rejected_unencrypted_share|node_name [-node node_name]
If you want to display information only for a single node, specify the optional
-node
parameter. -
Return to the admin privilege level:
set -privilege admin
The following example shows how you can monitor SMB 3.0 encryption statistics on storage virtual machine (SVM) vs1.
The following command moves to the advanced privilege level:
cluster1::> set -privilege advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by support personnel. Do you want to continue? {y|n}: y
The following command starts data collection for a new sample:
cluster1::*> statistics start -object cifs -sample-id smbencryption_sample -vserver vs1 Statistics collection is being started for Sample-id: smbencryption_sample
The following command stops data collection for that sample:
cluster1::*> statistics stop -sample-id smbencryption_sample Statistics collection is being stopped for Sample-id: smbencryption_sample
The following command shows encrypted SMB sessions and established SMB sessions by the node from the sample:
cluster2::*> statistics show -object cifs -counter established_sessions|encrypted_sessions|node_name –node node_name Object: cifs Instance: [proto_ctx:003] Start-time: 4/12/2016 11:17:45 End-time: 4/12/2016 11:21:45 Scope: vsim2 Counter Value ---------------------------- ---------------------- established_sessions 1 encrypted_sessions 1 2 entries were displayed
The following command shows the number of rejected unencrypted SMB sessions by the node from the sample:
clus-2::*> statistics show -object cifs -counter rejected_unencrypted_sessions –node node_name Object: cifs Instance: [proto_ctx:003] Start-time: 4/12/2016 11:17:45 End-time: 4/12/2016 11:21:51 Scope: vsim2 Counter Value ---------------------------- ---------------------- rejected_unencrypted_sessions 1 1 entry was displayed.
The following command shows the number of connected SMB shares and encrypted SMB shares by the node from the sample:
clus-2::*> statistics show -object cifs -counter connected_shares|encrypted_share_connections|node_name –node node_name Object: cifs Instance: [proto_ctx:003] Start-time: 4/12/2016 10:41:38 End-time: 4/12/2016 10:41:43 Scope: vsim2 Counter Value ---------------------------- ---------------------- connected_shares 2 encrypted_share_connections 1 2 entries were displayed.
The following command shows the number of rejected unencrypted SMB share connections by the node from the sample:
clus-2::*> statistics show -object cifs -counter rejected_unencrypted_shares –node node_name Object: cifs Instance: [proto_ctx:003] Start-time: 4/12/2016 10:41:38 End-time: 4/12/2016 10:42:06 Scope: vsim2 Counter Value -------------------------------- ---------------------- rejected_unencrypted_shares 1 1 entry was displayed.
Determining which statistics objects and counters are available
