Monitor SMB signed session statistics
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can monitor SMB sessions statistics and determine which established sessions are signed and which are not.
The statistics
command at the advanced privilege level provides the signed_sessions
counter that you can use to monitor the number of signed SMB sessions. The signed_sessions
counter is available with the following statistics objects:
cifs
enables you to monitor SMB signing for all SMB sessions. -
smb1
enables you to monitor SMB signing for SMB 1.0 sessions. -
smb2
enables you to monitor SMB signing for SMB 2.x and SMB 3.0 sessions.SMB 3.0 statistics are included in the output for the
smb2
object.
If you want to compare the number of signed session to the total number of sessions, you can compare output for the signed_sessions
counter with the output for the established_sessions
counter.
You must start a statistics sample collection before you can view the resultant data. You can view data from the sample if you do not stop data collection. Stopping data collection gives you a fixed sample. Not stopping data collection gives you the ability to get updated data that you can use to compare against previous queries. The comparison can help you identify trends.
Set the privilege level to advanced:
set -privilege advanced
Start a data collection:
statistics start -object {cifs|smb1|smb2} -instance instance -sample-id sample_ID [-node node_name]
If you do not specify the
-sample-id
parameter, the command generates a sample identifier for you and defines this sample as the default sample for the CLI session. The value for-sample-id
is a text string. If you run this command during the same CLI session and do not specify the-sample-id
parameter, the command overwrites the previous default sample.You can optionally specify the node on which you want to collect statistics. If you do not specify the node, the sample collects statistics for all nodes in the cluster.
Use the
statistics stop
command to stop collecting data for the sample. -
View SMB signing statistics:
If you want to view information for… Enter… Signed sessions
show -sample-id sample_ID -counter signed_sessions|node_name [-node node_name]
Signed sessions and established sessions
show -sample-id sample_ID -counter signed_sessions|established_sessions|node_name [-node node_name]
If you want to display information for only a single node, specify the optional
-node
parameter. -
Return to the admin privilege level:
set -privilege admin
The following example shows how you can monitor SMB 2.x and SMB 3.0 signing statistics on storage virtual machine (SVM) vs1.
The following command moves to the advanced privilege level:
cluster1::> set -privilege advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by support personnel. Do you want to continue? {y|n}: y
The following command starts data collection for a new sample:
cluster1::*> statistics start -object smb2 -sample-id smbsigning_sample -vserver vs1 Statistics collection is being started for Sample-id: smbsigning_sample
The following command stops the data collection for the sample:
cluster1::*> statistics stop -sample-id smbsigning_sample Statistics collection is being stopped for Sample-id: smbsigning_sample
The following command shows signed SMB sessions and established SMB sessions by node from the sample:
cluster1::*> statistics show -sample-id smbsigning_sample -counter signed_sessions|established_sessions|node_name Object: smb2 Instance: vs1 Start-time: 2/6/2013 01:00:00 End-time: 2/6/2013 01:03:04 Cluster: cluster1 Counter Value -------------------------------- ------------------------- established_sessions 0 node_name node1 signed_sessions 0 established_sessions 1 node_name node2 signed_sessions 1 established_sessions 0 node_name node3 signed_sessions 0 established_sessions 0 node_name node4 signed_sessions 0
The following command shows signed SMB sessions for node2 from the sample:
cluster1::*> statistics show -sample-id smbsigning_sample -counter signed_sessions|node_name -node node2 Object: smb2 Instance: vs1 Start-time: 2/6/2013 01:00:00 End-time: 2/6/2013 01:22:43 Cluster: cluster1 Counter Value -------------------------------- ------------------------- node_name node2 signed_sessions 1
The following command moves back to the admin privilege level:
cluster1::*> set -privilege admin
