Use statistics to monitor automatic node referral activity
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
To determine how many SMB connections are referred, you can monitor automatic node referral activity by using the statistics
command. By monitoring referrals you can determine the extent to which automatic referrals are locating connections on nodes that host the shares and whether you should redistribute your data LIFs to provide better local access to shares on the CIFS server.
The cifs
object provides several counters at the advanced privilege level that are helpful when monitoring SMB automatic node referrals:
node_referral_issued
Number of clients that have been issued a referral to the share root's node after the client connected using a LIF hosted by a node different from the share root's node.
node_referral_local
Number of clients that connected using a LIF hosted by the same node that hosts the share root. Local access generally provides optimal performance.
node_referral_not_possible
Number of clients that have not been issued a referral to the node hosting the share root after connecting using a LIF hosted by a node different from the share root's node. This is because an active data LIF for the share root's node was not found.
node_referral_remote
Number of clients that connected using a LIF hosted by a node different from the node that hosts the share root. Remote access might result in degraded performance.
You can monitor automatic node referral statistics on your storage virtual machine (SVM) by collecting and viewing data for a specific time period (a sample). You can view data from the sample if you do not stop data collection. Stopping data collection gives you a fixed sample. Not stopping data collection gives you the ability to get updated data that you can use to compare against previous queries. The comparison can help you identify performance trends.
To evaluate and use the information you gather from the |
Set the privilege level to advanced:
set -privilege advanced
View automatic node referral statistics by using the
statistics
command.This example views automatic node referral statistics by collecting and viewing data for a sampled time period:
Start the collection:
statistics start -object cifs -instance vs1 -sample-id sample1
Statistics collection is being started for Sample-id: sample1
Wait for the desired collection time to elapse.
Stop the collection:
statistics stop -sample-id sample1
Statistics collection is being stopped for Sample-id: sample1
View the automatic node referral statistics:
statistics show -sample-id sample1 -counter node
Object: cifs Instance: vs1 Start-time: 2/4/2013 19:27:02 End-time: 2/4/2013 19:30:11 Cluster: cluster1 Counter Value ----------------------------- --------------------------- node_name node1 node_referral_issued 0 node_referral_local 1 node_referral_not_possible 2 node_referral_remote 2 ... node_name node2 node_referral_issued 2 node_referral_local 1 node_referral_not_possible 0 node_referral_remote 2 ...
Output displays counters for all nodes participating in SVM vs1. For clarity, only output fields related to automatic node referral statistics are provided in the example.
Return to the admin privilege level:
set -privilege admin
