Supported Dynamic Access Control functionality
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
If you want to use Dynamic Access Control (DAC) on your CIFS server, you need to understand how ONTAP supports Dynamic Access Control functionality in Active Directory environments.
Supported for Dynamic Access Control
ONTAP supports the following functionality when Dynamic Access Control is enabled on the CIFS server:
Functionality | Comments |
Claims into the file system |
Claims are simple name and value pairs that state some truth about a user. User credentials contain claim information, and security descriptors on files can perform access checks that include claims checks. This gives administrators a finer level of control over who can access files. |
Conditional expressions to file access checks |
When modifying the security parameters of a file, users can add arbitrarily complex conditional expressions to the file's security descriptor. The conditional expression can include checks for claims. |
Central control of file access via central access policies |
Central access policies are a kind of ACL stored in Active Directory that can be tagged to a file. Access to the file is only granted if the access checks of both the security descriptor on disk and the tagged central access policy allows access.This gives administrators the ability to control access to files from a central location (AD) without having to modify the security descriptor on disk. |
Central access policy staging |
Adds the ability to try out security changes without affecting actual file access, by “staging” a change to the central access policies, and seeing the effect of the change in an audit report. |
Support for displaying information about central access policy security by using the ONTAP CLI |
Extends the |
Security tracing that includes central access policies |
Extends the |
Unsupported for Dynamic Access Control
ONTAP does not support the following functionality when Dynamic Access Control is enabled on the CIFS server:
Automatic classification of NTFS file system objects |
This is an extension to the Windows File Classification Infrastructure that is not supported in ONTAP. |
Advanced auditing other than central access policy staging |
Only central access policy staging is supported for advanced auditing. |
