Guidelines for using ODX
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Before you can use ODX for copy offload, you need to be aware of the guidelines. For example, you need to know on which types of volumes you can use ODX and you need to understand the intra-cluster and inter-cluster ODX considerations.
Volume guidelines
You cannot use ODX for copy offload with the following volume configurations:
Source volume size is less than 1.25 GB
The volume size must be 1.25 GB or larger to use ODX.
Read-only volumes
ODX is not used for files and folders residing in load-sharing mirrors or in SnapMirror or SnapVault destination volumes.
If the source volume is not deduplicated
ODX copies are supported only for intra-cluster copies.
You cannot use ODX to copy files or folders to a volume in another cluster.
Other guidelines
In SMB environments, to use ODX for copy offload, the files must be 256 kb or larger.
Smaller files are transferred using a traditional copy operation.
ODX copy offload uses deduplication as part of the copy process.
If you do not want deduplication to occur on SVM volumes when copying or moving data, you should disable ODX copy offload on that SVM.
The application that performs the data transfer must be written to support ODX.
Application operations that support ODX include the following:
Hyper-V management operations, such as creating and converting virtual hard disks (VHDs), managing Snapshot copies, and copying files between virtual machines
Windows Explorer operations
Windows PowerShell copy commands
Windows command prompt copy commands
Robocopy at the Windows command prompt supports ODX.
The applications must be running on Windows servers or clients that support ODX.
For more information about supported ODX applications on Windows servers and clients, consult the Microsoft TechNet Library.
Microsoft TechNet Library: technet.microsoft.com/en-us/library/
