Configure existing shares for continuous availability
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can modify existing shares to become continuously available shares that the Hyper-V and SQL Server application servers use to nondisruptively access Hyper-V virtual machine and configuration files and SQL Server database files.
You cannot use an existing share as a continuously available share for nondisruptive operations with application servers over SMB if the share has the following characteristics:
If the
homedirectory
share property is set on that share -
If the share contains enabled symlinks or widelinks
If the share contains junctioned volumes below the root of the share
You must verify that the two following share parameters are set correctly:
The
-offline-files
parameter is set to eithermanual
(the default) ornone
Symlinks must be disabled.
The following share properties must be configured:
continuously-available
oplocks
The following share properties must not be set. If they are present in the list of current share properties, they need to be removed from the continuously available share:
attributecache
branchcache
Display the current share parameter settings and the current list of configured share properties:
vserver cifs share show -vserver vserver_name -share-name share_name
If necessary, modify the share parameters to disable symlinks and set offline files to manual by using the
vserver cifs share properties modify
command.You can disable symlinks by setting the value of the
-symlink
parameter to""
-symlink
parameter to""
You can set the
-offline-files
parameter to the correct setting by specifyingmanual
Add the
share property, and, if needed, theoplocks
share property:vserver cifs share properties add -vserver vserver_name -share-name share_name -share-properties continuously-available[,oplock]
If the
oplocks
share property is not already set, you must add it along with thecontinuously-available
share property. -
Remove any share properties that are not supported on continuously available shares:
vserver cifs share properties remove -vserver vserver_name -share-name share_name -share-properties properties[,…]
You can remove one or more share properties by specifying the share properties with a comma-delimited list.
Verify that the
-symlink
and-offline-files
parameters are set correctly:vserver cifs share show -vserver vserver_name -share-name share_name -fields symlink-properties,offline-files
Verify that the list of configured share properties is correct:
vserver cifs shares properties show -vserver vserver_name -share-name share_name
The following example shows how to configure an existing share named “share1” on storage virtual machine (SVM) vs1 for NDOs with an application server over SMB:
Symlinks are disabled on the share by setting the
-symlink
parameter to "". -
The
-offline-file
parameter is modified and set tomanual
The
share property is added to the share. -
The
oplocks
share property is already in the list of share properties; therefore, it does not need to be added. -
The
attributecache
share property is removed from the share. -
The
browsable
share property is optional for a continuously available share used for NDOs with application servers over SMB and is retained as one of the share properties.
cluster1::> vserver cifs share show -vserver vs1 -share-name share1 Vserver: vs1 Share: share1 CIFS Server NetBIOS Name: vs1 Path: /data Share Properties: oplocks browsable attributecache Symlink Properties: enable File Mode Creation Mask: - Directory Mode Creation Mask: - Share Comment: - Share ACL: Everyone / Full Control File Attribute Cache Lifetime: 10s Volume Name: data Offline Files: documents Vscan File-Operations Profile: standard cluster1::> vserver cifs share modify -vserver vs1 -share-name share1 -offline-file manual -symlink "" cluster1::> vserver cifs share properties add -vserver vs1 -share-name share1 -share-properties continuously-available cluster1::> vserver cifs share properties remove -vserver vs1 -share-name share1 -share-properties attributecache cluster1::> vserver cifs share show -vserver vs1 -share-name share1 -fields symlink-properties,offline-files vserver share-name symlink-properties offline-files -------- ---------- ------------------ ------------- vs1 share1 - manual cluster1::> vserver cifs share properties show -vserver vs1 -share-name share1 Vserver: vs1 Share: share1 Share Properties: oplocks browsable continuously-available
