Configure the VSS shadow copy directory depth (for Hyper-V over SMB shares)
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Optionally, you can configure the maximum depth of directories within SMB shares on which to create shadow copies. This parameter is useful if you want to manually control the maximum level of subdirectories on which ONTAP should create shadow copies.
The VSS shadow copy feature must be enabled.
The default is to create shadow copies for a maximum of five subdirectories. If the value is set to 0
, ONTAP creates shadow copies for all subdirectories.
Although you can specify that the shadow copy set directory depth include more than five subdirectories or all subdirectories, there is a Microsoft requirement that shadow copy set creation must be completed within 60 seconds. Shadow copy set creation fails if it cannot be completed within this time. The shadow copy directory depth you choose must not cause the creation time to exceed the time limit. |
Set the privilege level to advanced:
set -privilege advanced
Set the VSS shadow copy directory depth to the desired level:
vserver cifs options modify -vserver vserver_name -shadowcopy-dir-depth integer
vserver cifs options modify -vserver vs1 -shadowcopy-dir-depth 6
Return to the admin privilege level:
set -privilege admin
