Create NTFS data volumes
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You must create NTFS data volumes on the storage virtual machine (SVM) before you can configure continuously available shares for use with Hyper-V or SQL Server over SMB application servers. Use the volume configuration worksheet to create your data volumes.
There are optional parameters that you can use to customize a data volume. For more information about customizing volumes, see the Logical storage management.
As you create your data volumes, you should not create junction points within a volume that contains the following:
Hyper-V files for which ONTAP makes shadow copies
SQL Server database files that are backed up using SQL Server
If you inadvertently create a volume that uses mixed or UNIX security style, you cannot change the volume to an NTFS security style volume and then directly use it to create continuously available shares for nondisruptive operations. Nondisruptive operations for Hyper-V and SQL Server over SMB do not work correctly unless the volumes used in the configuration are created as NTFS security-style volumes.You must either delete the volume and re-create the volume with NTFS security style, or you can map the volume on a Windows host and apply an ACL at the top of the volume and propagate the ACL to all files and folders in the volume. |
Create the data volume by entering the appropriate command:
If you want to create a volume in an SVM where the root volume security style is… Enter the command… NTFS
volume create -vserver vserver_name -volume volume_name -aggregate aggregate_name -size integer[KB|MB|GB|TB|PB] -junction-path path
Not NTFS
volume create -vserver vserver_name -volume volume_name -aggregate aggregate_name -size integer[KB|MB|GB|TB|PB]-security-style ntfs -junction-path path
Verify that the volume configuration is correct:
volume show -vserver vserver_name -volume volume_name
