ONTAP and licensing requirements
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You need to be aware of certain ONTAP and licensing requirements when creating SQL Server or Hyper-V over SMB solutions for nondisruptive operations on SVMs.
ONTAP version requirements
Hyper-V over SMB
ONTAP supports nondisruptive operations over SMB shares for Hyper-V running on Windows 2012 or later.
SQL Server over SMB
ONTAP supports nondisruptive operations over SMB shares for SQL Server 2012 or later running on Windows 2012 or later.
For the latest information about supported versions of ONTAP, Windows Server, and SQL Server for nondisruptive operations over SMB shares, see the Interoperability Matrix.
Licensing requirements
The following licenses are required:
CIFS
FlexClone (for Hyper-V over SMB only)
This license is required if Remote VSS is used for backups. The shadow copy service uses FlexClone to create point-in-time copies of files that are then used when creating a backup.
A FlexClone license is optional if you use a backup method that does not use Remote VSS.
You should verify that the required licenses are installed, and, if necessary, install them.
