Prerequisites
PDF of this doc site
Cluster administration
Volume administration
Logical storage management with the CLI
NAS storage management
Configure NFS with the CLI
Manage NFS with the CLI
Manage SMB with the CLI
Manage file access using SMB
Security and data encryption
Data protection and disaster recovery
Creating your file...
When planning your SnapMirror active sync deployment, ensure you have met the various hardware, software, and system configuration requirements.
Hardware
Only two-node HA clusters are supported
Both clusters must be either AFF (including AFF C-Series) or All-Flash SAN Array (ASA; includding C-Series). Mixing is not supported.
Software
ONTAP 9.9.1 or later
ONTAP Mediator 1.2 or later
A Linux server or virtual machine for the ONTAP Mediator running one of the following:
ONTAP Mediator version |
Supported Linux versions |
1.8 |
1.7 |
1.6 |
1.5 |
1.4 |
1.3 |
1.2 |
Licensing
SnapMirror synchronous license must be applied on both clusters.
SnapMirror license must be applied on both clusters.
If your ONTAP storage systems were purchased before June 2019, see NetApp ONTAP Master License Keys to get the required SnapMirror synchronous license.
Networking environment
Inter-cluster latency round trip time (RTT) must be less than 10 milliseconds.
Beginning with ONTAP 9.14.1, SCSI-3 persistent reservations are supported with SnapMirror active sync.
Supported protocols
Only SAN protocols are supported (not NFS/SMB).
Only Fibre Channel and iSCSI protocols are supported.
The default IPspace is required by SnapMirror active sync for cluster peer relationships. Custom IPspace is not supported.
NTFS Security Style
NTFS security style is not supported on SnapMirror active sync volumes.
ONTAP Mediator
The ONTAP Mediator must be provisioned externally and attached to ONTAP for transparent application failover.
To be fully functional and to enable automatic unplanned failover, the external ONTAP mediator should be provisioned and configured with ONTAP clusters.
The ONTAP Mediator must be installed in a third failure domain, separate from the two ONTAP clusters.
When installing the ONTAP Mediator, you should replace the self-signed certificate with a valid certificate signed by a mainstream reliable CA.
For more information about the ONTAP Mediator, see Prepare to install the ONTAP Mediator service.
Read-write destination volumes
SnapMirror active sync relationships are not supported on read-write destination volumes. Before you can use a read-write volume, you must convert it to a DP volume by creating a volume-level SnapMirror relationship and then deleting the relationship. For details, see Convert an existing SnapMirror relationships to SnapMirror active sync.
