Access the cluster by using RSH
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can issue RSH requests to the cluster to perform administrative tasks. RSH is not a secure protocol and is disabled by default.
The following conditions must be met before you can use RSH to access the cluster:
You must have a cluster local user account that is configured to use RSH as an access method.
The
-application
parameter of thesecurity login
commands specifies the access method for a user account. For more information, see thesecurity login
man pages. -
RSH must already be enabled in the management firewall policy that is used by the cluster or node management LIFs so that RSH requests can go through the firewall.
By default, RSH is disabled. The
system services firewall policy show
command with the-service rsh
parameter displays whether RSH has been enabled in a firewall policy. For more information, see thesystem services firewall policy
man pages. -
If you use IPv6 connections, IPv6 must already be configured and enabled on the cluster, and firewall policies must already be configured with IPv6 addresses.
The
network options ipv6 show
command displays whether IPv6 is enabled. Thesystem services firewall policy show
command displays firewall policies.
RSH is not a secure protocol.
You should consider using SSH to access the cluster. SSH provides a secure remote shell and interactive network session.
ONTAP supports a maximum of 50 concurrent RSH sessions per node.
If the cluster management LIF resides on the node, it shares this limit with the node management LIF.
If the rate of in-coming connections is higher than 10 per second, the service is temporarily disabled for 60 seconds.
From an administration host, enter the following command:
rsh hostname_or_IP -l username:passwordcommand
hostname_or_IP
is the host name or the IP address of the cluster management LIF or a node management LIF. Using the cluster management LIF is recommended. You can use an IPv4 or IPv6 address.command
is the command you want to execute over RSH.
The following example shows how the user named “joe”, who has been set up with RSH access, can issue an RSH request to run the cluster show
command:
admin_host$ rsh 10.72.137.28 -l joe:password cluster show Node Health Eligibility --------------------- ------- ------------ node1 true true node2 true true 2 entries were displayed. admin_host$
