Access the SP/BMC from the system console
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can access the SP from the system console (also called serial console) to perform monitoring or troubleshooting tasks.
This task applies to both the SP and the BMC.
Access the SP CLI from the system console by pressing Ctrl-G at the prompt.
Log in to the SP CLI when you are prompted.
The SP prompt appears, indicating that you have access to the SP CLI.
Exit the SP CLI and return to the system console by pressing Ctrl-D, and then press Enter.
The following example shows the result of pressing Ctrl-G from the system console to access the SP CLI. The help system power
command is entered at the SP prompt, followed by pressing Ctrl-D and then Enter to return to the system console.
cluster1::>
(Press Ctrl-G to access the SP CLI.)
Switching console to Service Processor Service Processor Login: Password: SP> SP> help system power system power cycle - power the system off, then on system power off - power the system off system power on - power the system on system power status - print system power status SP>
(Press Ctrl-D and then Enter to return to the system console.)
cluster1::>
