Use of administrative privilege levels
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
ONTAP commands and parameters are defined at three privilege levels: admin, advanced, and diagnostic. The privilege levels reflect the skill levels required in performing the tasks.
admin
Most commands and parameters are available at this level. They are used for common or routine tasks.
advanced
Commands and parameters at this level are used infrequently, require advanced knowledge, and can cause problems if used inappropriately.
You use advanced commands or parameters only with the advice of support personnel.
diagnostic
Diagnostic commands and parameters are potentially disruptive. They are used only by support personnel to diagnose and fix problems.
