Manage audit GET request settings
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
While SET requests are logged by default, GET requests are not. However, you can control whether GET requests sent from ONTAP HTML (-httpget
), the ONTAP CLI (-cliget
), or from the ONTAP APIs (-ontapiget
) are logged in the file.
You can modify audit logging settings from the ONTAP CLI, and beginning with ONTAP 9.11.1, from System Manager.
Select Events & Jobs > Audit Logs.
Click in the upper-right corner, then choose the requests to add or remove.
To specify that GET requests from the ONTAP CLI or APIs should be recorded in the audit log (the audit.log file), in addition to default set requests, enter:
security audit modify [-cliget {on|off}][-httpget {on|off}][-ontapiget {on|off}]
To display the current settings, enter:
security audit show
See the man pages for details.
