How AutoSupport creates and sends event-triggered messages
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
AutoSupport creates event-triggered AutoSupport messages when the EMS processes a trigger event. An event-triggered AutoSupport message alerts recipients to problems that require corrective action and contains only information that is relevant to the problem. You can customize what content to include and who receives the messages.
AutoSupport uses the following process to create and send event-triggered AutoSupport messages:
When the EMS processes a trigger event, EMS sends AutoSupport a request.
A trigger event is an EMS event with an AutoSupport destination and a name that begins with a
callhome.
prefix. -
AutoSupport creates an event-triggered AutoSupport message.
AutoSupport collects basic and troubleshooting information from subsystems that are associated with the trigger to create a message that includes only information that is relevant to the trigger event.
A default set of subsystems is associated with each trigger. However, you can choose to associate additional subsystems with a trigger by using the
system node autosupport trigger modify
command. -
AutoSupport sends the event-triggered AutoSupport message to the recipients defined by the
system node autosupport modify
command with the-to
,-noteto
,-partner-address
, and-support
parameters.You can enable and disable delivery of AutoSupport messages for specific triggers by using the
command with the-to
and-noteto
parameters.
The storage shelf PSU failed
EMS event triggers a message that contains basic data from the Mandatory, Log Files, Storage, RAID, HA, Platform, and Networking subsystems and troubleshooting data from the Mandatory, Log Files, and Storage subsystems.
You decide that you want to include data about NFS in any AutoSupport messages sent in response to a future storage shelf PSU failed
event. You enter the following command to enable troubleshooting-level data for NFS for the callhome.shlf.ps.fault
event:
cluster1::\> system node autosupport trigger modify -node node1 -autosupport-message shlf.ps.fault -troubleshooting-additional nfs
Note that the callhome.
prefix is dropped from the callhome.shlf.ps.fault
event when you use the system node autosupport trigger
commands, or when referenced by AutoSupport and EMS events in the CLI.
