Information included in the AutoSupport manifest
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
The AutoSupport manifest provides you with a detailed view of the files collected for each AutoSupport message. The AutoSupport manifest also includes information about collection errors when AutoSupport cannot collect the files it needs.
The AutoSupport manifest includes the following information:
Sequence number of the AutoSupport message
Which files AutoSupport included in the AutoSupport message
Size of each file, in bytes
Status of the AutoSupport manifest collection
Error description, if AutoSupport failed to collect one or more files
You can view the AutoSupport manifest by using the system node autosupport manifest show
command.
The AutoSupport manifest is included with every AutoSupport message and presented in XML format, which means that you can either use a generic XML viewer to read it or view it using the Active IQ (formerly known as My AutoSupport) portal.
