BMC CLI commands
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
You can log into the BMC using SSH. The following commands are supported from the BMC command line.
Command | Function |
system |
Display a list of all commands. |
system console |
Connect to the system's console. Use |
system core |
Dump the system core and reset. |
system power cycle |
Power the system off, then on. |
system power off |
Power the system off. |
system power on |
Power the system on. |
system power status |
Print system power status. |
system reset |
Reset the system. |
system log |
Print system console logs |
system fru show [id] |
Dump all/selected field replaceable unit (FRU) info. |
