Commands for managing licenses
Contributors netapp-lenida netapp-thomi netapp-ahibbard
You can use the ONTAP CLI system license commands to manage feature licenses for the cluster. You use the system feature-usage commands to monitor feature usage.
The following table lists some of the common CLI commands for managing licenses and links to the command man pages for additional information.
If you want to…​ Use this command…​
Display all packages that require licenses and their current license status, including the following:
  • The package name
  • The licensed method
  • The expiration date, if applicable
Display or remove expired or unused licenses
Display summary of feature usage in the cluster on a per-node basis
Display feature usage status in the cluster on a per-node and per-week basis
Display the status of license entitlement risk for each license package
Related information
ONTAP 9 Commands
