Commands for managing SSL
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
You use the security ssl
commands to manage the SSL protocol for the cluster ora storage virtual machine (SVM).
If you want to… | Use this command… |
Enable SSL for the cluster oranSVM, and associate a digital certificate with it |
Display the SSL configuration and certificate name for the cluster oranSVM |
