Commands for managing the web protocol engine
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You use the system services web
commands to manage the web protocol engine. You use the system services firewall policy create
and network interface modify
commands to allow web access requests to go through the firewall.
If you want to… | Use this command… |
Configure the web protocol engine at the cluster level:
Display the configuration of the web protocol engine at the cluster level, determine whether the web protocols are functional throughout the cluster, and display whether FIPS 140-2 compliance is enabled and online |
Display the configuration of the web protocol engine at the node level and the activity of web service handling for the nodes in the cluster |
Create a firewall policy or add HTTP or HTTPS protocol service to an existing firewall policy to allow web access requests to go through firewall |
Setting the |
Associate a firewall policy with a LIF |
You can use the |
