Configure the SP/BMC network manually
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
If you do not have automatic network configuration set up for the SP, you must manually configure a node's SP network for the SP to be accessible by using an IP address.
If you want to use IPv6 connections for the SP, IPv6 must already be configured and enabled for ONTAP. The network options ipv6
commands manage IPv6 settings for ONTAP.
This task applies to both the SP and the BMC. |
You can configure the SP to use IPv4, IPv6, or both. The SP IPv4 configuration supports static and DHCP addressing, and the SP IPv6 configuration supports static addressing only.
If the SP automatic network configuration has been set up, you do not need to manually configure the SP network for individual nodes, and the system service-processor network modify
command allows you to only enable or disable the SP network interface.
Configure the SP network for a node by using the
command.-
The
-address-family
parameter specifies whether the IPv4 or IPv6 configuration of the SP is to be modified. -
The
-enable
parameter enables the network interface of the specified IP address family. -
The
-dhcp
parameter specifies whether to use the network configuration from the DHCP server or the network address that you provide.You can enable DHCP (by setting
-dhcp
tov4
) only if you are using IPv4. You cannot enable DHCP for IPv6 configurations. -
The
-ip-address
parameter specifies the public IP address for the SP.A warning message appears when you attempt to manually configure the SP network with addresses that are allocated to a subnet. Ignoring the warning and proceeding with the manual address assignment might result in a duplicate address assignment.
The
-netmask
parameter specifies the netmask for the SP (if using IPv4.) -
The
-prefix-length
parameter specifies the network prefix-length of the subnet mask for the SP (if using IPv6.) -
The
-gateway
parameter specifies the gateway IP address for the SP.
Configure the SP network for the remaining nodes in the cluster by repeating the step 1.
Display the SP network configuration and verify the SP setup status by using the
system service-processor network show
command with the–instance
or–field setup-status
parameters.The SP setup status for a node can be one of the following:
not-setup
— Not configured -
succeeded
— Configuration succeeded -
in-progress
— Configuration in progress -
failed
— Configuration failed
The following example configures the SP of a node to use IPv4, enables the SP, and displays the SP network configuration to verify the settings:
cluster1::> system service-processor network modify -node local -address-family IPv4 -enable true -ip-address 192.168.123.98 -netmask 255.255.255.0 -gateway 192.168.123.1 cluster1::> system service-processor network show -instance -node local Node: node1 Address Type: IPv4 Interface Enabled: true Type of Device: SP Status: online Link Status: up DHCP Status: none IP Address: 192.168.123.98 MAC Address: ab:cd:ef:fe:ed:02 Netmask: 255.255.255.0 Prefix Length of Subnet Mask: - Router Assigned IP Address: - Link Local IP Address: - Gateway IP Address: 192.168.123.1 Time Last Updated: Thu Apr 10 17:02:13 UTC 2014 Subnet Name: - Enable IPv6 Router Assigned Address: - SP Network Setup Status: succeeded SP Network Setup Failure Reason: - 1 entries were displayed. cluster1::>
