Manage access to web services
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
A web service is an application that users can access by using HTTP or HTTPS. The cluster administrator can set up the web protocol engine, configure SSL, enable a web service, and enable users of a role to access a web service.
Beginning with ONTAP 9.6, the following web services are supported:
Service Processor Infrastructure (
spi
)This service makes a node's log, core dump, and MIB files available for HTTP or HTTPS access through the cluster management LIF or a node management LIF. The default setting is
enabled
.Upon a request to access a node's log files or core dump files, the
spi
web service automatically creates a mount point from a node to another node's root volume where the files reside. You do not need to manually create the mount point. ` -
ONTAP APIs (
ontapi
)This service enables you to run ONTAP APIs to execute administrative functions with a remote program. The default setting is
enabled
.This service might be required for some external management tools. For example, if you use System Manager, you should leave this service enabled.
Data ONTAP Discovery (
disco
)This service enables off-box management applications to discover the cluster in the network. The default setting is
enabled
Support Diagnostics (
supdiag
)This service controls access to a privileged environment on the system to assist problem analysis and resolution. The default setting is
disabled
. You should enable this service only when directed by technical support. -
System Manager (
sysmgr
)This service controls the availability of System Manager, which is included with ONTAP. The default setting is
enabled
. This service is supported only on the cluster. -
Firmware Baseboard Management Controller (BMC) Update (
FW_BMC
)This service enables you to download BMC firmware files. The default setting is
enabled
ONTAP Documentation (
docs
)This service provides access to the ONTAP documentation. The default setting is
enabled
ONTAP RESTful APIs (
docs_api
)This service provides access to the ONTAP RESTful API documentation. The default setting is
enabled
File Upload and Download (
fud
)This service offers file upload and download. The default setting is
enabled
ONTAP Messaging (
ontapmsg
)This service supports a publish and subscribe interface allowing you to subscribe to events. The default setting is
enabled
ONTAP Portal (
portal
)This service implements the gateway into a virtual server. The default setting is
enabled
ONTAP Restful Interface (
rest
)This service supports a RESTful interface that is used to remotely manage all elements of the cluster infrastructure. The default setting is
enabled
Security Assertion Markup Language (SAML) Service Provider Support (
saml
)This service provides resources to support the SAML service provider. The default setting is
enabled
SAML Service Provider (
saml-sp
)This service offers services such as SP metadata and the assertion consumer service to the service provider. The default setting is
enabled
Beginning with ONTAP 9.7, the following additional services are supported:
Configuration Backup Files (
backups
)This service enables you to download configuration backup files. The default setting is
enabled
ONTAP Security (
security
)This service supports CSRF token management for enhanced authentication. The default setting is
enabled
