Managing the banner
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can manage the banner at the cluster or SVM level. The banner configured for the cluster is also used for all SVMs that do not have a banner message defined. A subsequently created banner for an SVM overrides the cluster banner for that SVM.
Manage the banner at the cluster level:
If you want to… Then… Create a banner to display for all CLI login sessions
Set a cluster-level banner:
security login banner modify -vserver cluster_name { [-message "text"] | [-uri ftp_or_http_addr] }
Remove the banner for all (cluster and SVM) logins
Set the banner to an empty string (
):security login banner modify -vserver * -message ""
Override a banner created by an SVM administrator
Modify the SVM banner message:
security login banner modify -vserver svm_name { [-message "text"] | [-uri ftp_or_http_addr] }
Manage the banner at the SVM level:
Specifying
-vserver svm_name
is not required in the SVM context.If you want to… Then… Override the banner supplied by the cluster administrator with a different banner for the SVM
Create a banner for the SVM:
Suppress the banner supplied by the cluster administrator so that no banner is displayed for the SVM
Set the SVM banner to an empty string for the SVM:
security login banner modify -vserver svm_name -message ""
Use the cluster-level banner when the SVM currently uses an SVM-level banner
:security login banner modify -vserver svm_name -message "-"
