Manage CLI sessions
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You can record a CLI session into a file with a specified name and size limit, then upload the file to an FTP or HTTP destination. You can also display or delete files in which you previously recorded CLI sessions.
Record a CLI session
A record of a CLI session ends when you stop the recording or end the CLI session, or when the file reaches the specified size limit. The default file size limit is 1 MB. The maximum file size limit is 2 GB.
Recording a CLI session is useful, for example, if you are troubleshooting an issue and want to save detailed information or if you want to create a permanent record of space usage at a specific point in time.
Start recording the current CLI session into a file:
system script start
For more information about using the
system script start
command, see the man page.ONTAP starts recording your CLI session into the specified file.
Proceed with your CLI session.
When finished, stop recording the session:
system script stop
system script stop
command, see the man page.ONTAP stops recording your CLI session.
Commands for managing records of CLI sessions
You use the system script
commands to manage records of CLI sessions.
If you want to… | Use this command… |
Start recording the current CLI session in to a specified file |
Stop recording the current CLI session |
Display information about records of CLI sessions |
Upload a record of a CLI session to an FTP or HTTP destination |
Delete a record of a CLI session |
Commands for managing the automatic timeout period of CLI sessions
The timeout value specifies how long a CLI session remains idle before being automatically terminated. The CLI timeout value is cluster-wide. That is, every node in a cluster uses the same CLI timeout value.
By default, the automatic timeout period of CLI sessions is 30 minutes.
You use the system timeout
commands to manage the automatic timeout period of CLI sessions.
Display the automatic timeout period for CLI sessions |
Modify the automatic timeout period for CLI sessions |
