Manage core dumps (cluster administrators only)
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
When a node panics, a core dump occurs and the system creates a core dump file that technical support can use to troubleshoot the problem. You can configure or display core dump attributes. You can also save, display, segment, upload, or delete a core dump file.
You can manage core dumps in the following ways:
Configuring core dumps and displaying the configuration settings
Displaying basic information, the status, and attributes of core dumps
Core dump files and reports are stored in the
/mroot/etc/crash/
directory of a node. You can display the directory content by using thesystem node coredump
commands or a web browser. -
Saving the core dump content and uploading the saved file to a specified location or to technical support
ONTAP prevents you from initiating the saving of a core dump file during a takeover, an aggregate relocation, or a giveback.
Deleting core dump files that are no longer needed
Commands for managing core dumps
You use the system node coredump config
commands to manage the configuration of core dumps, the system node coredump
commands to manage the core dump files, and the system node coredump reports
commands to manage application core reports.
If you want to… | Use this command… | ||
Configure core dumps |
Display the configuration settings for core dumps |
Display basic information about core dumps |
Manually trigger a core dump when you reboot a node |
Manually trigger a core dump when you shut down a node |
Save a specified core dump |
Save all unsaved core dumps that are on a specified node |
Generate and send an AutoSupport message with a core dump file you specify |
Display status information about core dumps |
Delete a specified core dump |
Delete all unsaved core dumps or all saved core files on a node |
Display application core dump reports |
Delete an application core dump report |
