Manage web services overview
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can enable or disable a web service for the cluster or a storage virtual machine (SVM), display the settings for web services, and control whether users of a role can access a web service.
You can manage web services for the cluster or an SVM in the following ways:
Enabling or disabling a specific web service
Specifying whether access to a web service is restricted to only encrypted HTTP (SSL)
Displaying the availability of web services
Allowing or disallowing users of a role to access a web service
Displaying the roles that are permitted to access a web service
For a user to access a web service, all of the following conditions must be met:
The user must be authenticated.
For instance, a web service might prompt for a user name and password. The user's response must match a valid account.
The user must be set up with the correct access method.
Authentication only succeeds for users with the correct access method for the given web service. For the ONTAP API web service (
ontapi
), users must have theontapi
access method. For all other web services, users must have thehttp
access method.You use the
security login
commands to manage users' access methods and authentication methods. -
The web service must be configured to allow the user's access-control role.
You use the
vserver services web access
commands to control a role's access to a web service.
If a firewall is enabled, the firewall policy for the LIF to be used for web services must be set up to allow HTTP or HTTPS.
If you use HTTPS for web service access, SSL for the cluster or SVM that offers the web service must also be enabled, and you must provide a digital certificate for the cluster or SVM.
