Methods of managing SP/BMC firmware updates
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
ONTAP includes an SP firmware image that is called the baseline image. If a new version of the SP firmware becomes subsequently available, you have the option to download it and update the SP firmware to the downloaded version without upgrading the ONTAP version.
This topic applies to both the SP and the BMC. |
ONTAP offers the following methods for managing SP firmware updates:
The SP automatic update functionality is enabled by default, allowing the SP firmware to be automatically updated in the following scenarios:
When you upgrade to a new version of ONTAP
The ONTAP upgrade process automatically includes the SP firmware update, provided that the SP firmware version bundled with ONTAP is newer than the SP version running on the node.
ONTAP detects a failed SP automatic update and triggers a corrective action to retry the SP automatic update up to three times. If all three retries fail, see the Knowledge Base article link: Health Monitor SPAutoUpgradeFailedMajorAlert SP upgrade fails - AutoSupport Message.
When you download a version of the SP firmware from the NetApp Support Site and the downloaded version is newer than the one that the SP is currently running
When you downgrade or revert to an earlier version of ONTAP
The SP firmware is automatically updated to the newest compatible version that is supported by the ONTAP version you reverted or downgraded to. A manual SP firmware update is not required.
You have the option to disable the SP automatic update functionality by using the
system service-processor image modify
command. However, it is recommended that you leave the functionality enabled. Disabling the functionality can result in suboptimal or nonqualified combinations between the ONTAP image and the SP firmware image. -
ONTAP enables you to trigger an SP update manually and specify how the update should take place by using the
system service-processor image update
command.You can specify the following options:
The SP firmware package to use (
-package
)You can update the SP firmware to a downloaded package by specifying the package file name. The advance
system image package show
command displays all package files (including the files for the SP firmware package) that are available on a node. -
Whether to use the baseline SP firmware package for the SP update (
-baseline
)You can update the SP firmware to the baseline version that is bundled with the currently running version of ONTAP.
If you use some of the more advanced update options or parameters, the BMC's configuration settings may be temporarily cleared. After reboot, it can take up to 10 minutes for ONTAP to restore the BMC configuration.
ONTAP enables you to display the status for the latest SP firmware update triggered from ONTAP by using the
system service-processor image update-progress show
command.
Any existing connection to the SP is terminated when the SP firmware is being updated. This is the case whether the SP firmware update is automatically or manually triggered.
