Modify cluster attributes
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
You can modify a cluster's attributes, such as the cluster name, location, and contact information as needed.
About this task
You cannot change a cluster's UUID, which is set when the cluster is created.
Steps
To modify cluster attributes, use the
cluster identity modify
command.The
-name
parameter specifies the name of the cluster. Thecluster identity modify
man page describes the rules for specifying the cluster's name.The
-location
parameter specifies the location for the cluster.The
-contact
parameter specifies the contact information such as a name or e-mail address.
Example of renaming a cluster
The following command renames the current cluster (“cluster1”) to “cluster2”:
cluster1::> cluster identity modify -name cluster2
