Set the privilege level in the CLI
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
You can set the privilege level in the CLI by using the set
command. Changes to privilege level settings apply only to the session you are in. They are not persistent across sessions.
Steps
To set the privilege level in the CLI, use the
set
command with the-privilege
parameter.
Example of setting the privilege level
The following example sets the privilege level to advanced and then to admin:
cluster1::> set -privilege advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel. Do you wish to continue? (y or n): y cluster1::*> set -privilege admin
