About the discrete SP sensor status values of the system sensors command output
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Discrete sensors do not have thresholds. Their readings, displayed under the Current
column in the SP CLI system sensors
command output, do not carry actual meanings and thus are ignored by the SP. The Status
column in the system sensors
command output displays the status values of discrete sensors in hexadecimal format.
Examples of discrete sensors include sensors for the fan, power supply unit (PSU) fault, and system fault. The specific list of discrete sensors depends on the platform.
You can use the SP CLI system sensors get
sensor_name
command for help with interpreting the status values for most discrete sensors. The following examples show the results of entering system sensors get
sensor_name
for the discrete sensors CPU0_Error and IO_Slot1_Present:
SP node1> system sensors get CPU0_Error Locating sensor record... Sensor ID : CPU0_Error (0x67) Entity ID : 7.97 Sensor Type (Discrete): Temperature States Asserted : Digital State [State Deasserted]
SP node1> system sensors get IO_Slot1_Present Locating sensor record... Sensor ID : IO_Slot1_Present (0x74) Entity ID : 11.97 Sensor Type (Discrete): Add-in Card States Asserted : Availability State [Device Present]
Although the system sensors get
sensor_name
command displays the status information for most discrete sensors, it does not provide status information for the System_FW_Status, System_Watchdog, PSU1_Input_Type, and PSU2_Input_Type discrete sensors. You can use the following information to interpret these sensors' status values.
System_FW_Status
The System_FW_Status sensor's condition appears in the form of 0xAABB
. You can combine the information of AA
and BB
to determine the condition of the sensor.
AA
can have one of the following values:
Values | Condition of the sensor |
01 |
System firmware error |
02 |
System firmware hang |
04 |
System firmware progress |
BB
00 |
System software has properly shut down |
01 |
Memory initialization in progress |
02 |
NVMEM initialization in progress (when NVMEM is present) |
04 |
Restoring memory controller hub (MCH) values (when NVMEM is present) |
05 |
User has entered Setup |
13 |
Booting the operating system or LOADER |
1F |
BIOS is starting up |
20 |
LOADER is running |
21 |
LOADER is programming the primary BIOS firmware. You must not power down the system. |
22 |
LOADER is programming the alternate BIOS firmware. You must not power down the system. |
2F |
ONTAP is running |
60 |
SP has powered off the system |
61 |
SP has powered on the system |
62 |
SP has reset the system |
63 |
SP watchdog power cycle |
64 |
SP watchdog cold reset |
For instance, the System_FW_Status sensor status 0x042F means "system firmware progress (04), ONTAP is running (2F)."
System_Watchdog
The System_Watchdog sensor can have one of the following conditions:
0x0080
The state of this sensor has not changed
0x0081 |
Timer interrupt |
0x0180 |
Timer expired |
0x0280 |
Hard reset |
0x0480 |
Power down |
0x0880 |
Power cycle |
For instance, the System_Watchdog sensor status 0x0880 means a watchdog timeout occurs and causes a system power cycle.
PSU1_Input_Type and PSU2_Input_Type
For direct current (DC) power supplies, the PSU1_Input_Type and PSU2_Input_Type sensors do not apply. For alternating current (AC) power supplies, the sensors' status can have one of the following values:
0x01 xx |
220V PSU type |
0x02 xx |
110V PSU type |
For instance, the PSU1_Input_Type sensor status 0x0280 means that the sensor reports that the PSU type is 110V.
