About the threshold-based SP sensor readings and status values of the system sensors command output
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- SAN storage management
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Threshold-based sensors take periodic readings of a variety of system components. The SP compares the reading of a threshold-based sensor against its preset threshold limits that define a component's acceptable operating conditions.
Based on the sensor reading, the SP displays the sensor state to help you monitor the condition of the component.
Examples of threshold-based sensors include sensors for the system temperatures, voltages, currents, and fan speeds. The specific list of threshold-based sensors depends on the platform.
Threshold-based sensors have the following thresholds, displayed in the output of the SP system sensors
command:
Lower critical (LCR)
Lower noncritical (LNC)
Upper noncritical (UNC)
Upper critical (UCR)
A sensor reading between LNC and LCR or between UNC and UCR means that the component is showing signs of a problem and a system failure might occur as a result. Therefore, you should plan for component service soon.
A sensor reading below LCR or above UCR means that the component is malfunctioning and a system failure is about to occur. Therefore, the component requires immediate attention.
The following diagram illustrates the severity ranges that are specified by the thresholds:
You can find the reading of a threshold-based sensor under the Current
column in the system sensors
command output. The system sensors get
sensor_name
command displays additional details for the specified sensor. As the reading of a threshold-based sensor crosses the noncritical and critical threshold ranges, the sensor reports a problem of increasing severity. When the reading exceeds a threshold limit, the sensor's status in the system sensors
command output changes from ok
to nc
(noncritical) or cr
(critical) depending on the exceeded threshold, and an event message is logged in the SEL event log.
Some threshold-based sensors do not have all four threshold levels. For those sensors, the missing thresholds show na
as their limits in the system sensors
command output, indicating that the particular sensor has no limit or severity concern for the given threshold and the SP does not monitor the sensor for that threshold.
The following example shows some of the information displayed by the system sensors
command in the SP CLI:
SP node1> system sensors Sensor Name | Current | Unit | Status| LCR | LNC | UNC | UCR -----------------+------------+------------+-------+-----------+-----------+-----------+----------- CPU0_Temp_Margin | -55.000 | degrees C | ok | na | na | -5.000 | 0.000 CPU1_Temp_Margin | -56.000 | degrees C | ok | na | na | -5.000 | 0.000 In_Flow_Temp | 32.000 | degrees C | ok | 0.000 | 10.000 | 42.000 | 52.000 Out_Flow_Temp | 38.000 | degrees C | ok | 0.000 | 10.000 | 59.000 | 68.000 CPU1_Error | 0x0 | discrete | 0x0180| na | na | na | na CPU1_Therm_Trip | 0x0 | discrete | 0x0180| na | na | na | na CPU1_Hot | 0x0 | discrete | 0x0180| na | na | na | na IO_Mid1_Temp | 30.000 | degrees C | ok | 0.000 | 10.000 | 55.000 | 64.000 IO_Mid2_Temp | 30.000 | degrees C | ok | 0.000 | 10.000 | 55.000 | 64.000 CPU_VTT | 1.106 | Volts | ok | 1.028 | 1.048 | 1.154 | 1.174 CPU0_VCC | 1.154 | Volts | ok | 0.834 | 0.844 | 1.348 | 1.368 3.3V | 3.323 | Volts | ok | 3.053 | 3.116 | 3.466 | 3.546 5V | 5.002 | Volts | ok | 4.368 | 4.465 | 5.490 | 5.636 STBY_1.8V | 1.794 | Volts | ok | 1.678 | 1.707 | 1.892 | 1.911 …
The following example shows the result of entering system sensors get
sensor_name
in the SP CLI for the threshold-based sensor 5V:
SP node1> system sensors get 5V Locating sensor record... Sensor ID : 5V (0x13) Entity ID : 7.97 Sensor Type (Analog) : Voltage Sensor Reading : 5.002 (+/- 0) Volts Status : ok Lower Non-Recoverable : na Lower Critical : 4.246 Lower Non-Critical : 4.490 Upper Non-Critical : 5.490 Upper Critical : 5.758 Upper Non-Recoverable : na Assertion Events : Assertions Enabled : lnc- lcr- ucr+ Deassertions Enabled : lnc- lcr- ucr+
