Troubleshoot the AutoSupport subsystem
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
The system node check show
commands can be used to verify and troubleshoot any issues related to the AutoSupport configuration and delivery.
Step
Use the following commands to display the status of the AutoSupport subsystem.
Use this command… To do this… system node autosupport check show
Display overall status of the AutoSupport subsystem, such as the status of AutoSupport HTTP or HTTPS destination, AutoSupport SMTP destinations, AutoSupport OnDemand Server, and AutoSupport configuration
system node autosupport check show-details
Display detailed status of the AutoSupport subsystem, such as detailed descriptions of errors and the corrective actions
