Verify digital certificates are valid using OCSP
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Beginning with ONTAP 9.2, Online Certificate Status Protocol (OCSP) enables ONTAP applications that use Transport Layer Security (TLS) communications to receive digital certificate status when OCSP is enabled. You can enable or disable OCSP certificate status checks for specific applications at any time. By default, OCSP certificate status checking is disabled.
You need advanced privilege level access to perform this task.
OCSP supports the following applications:
AutoSupport
Event Management System (EMS)
LDAP over TLS
Key Management Interoperability Protocol (KMIP)
Audit Logging
FabricPool
SSH (beginning with ONTAP 9.13.1)
Set the privilege level to advanced:
set -privilege advanced
To enable or disable OCSP certificate status checks for specific ONTAP applications, use the appropriate command.
If you want OCSP certificate status checks for some applications to be… Use the command… Enabled
security config ocsp enable -app
app name
Disabled
security config ocsp disable -app
app name
The following command enables OCSP support for AutoSupport and EMS.
cluster::*> security config ocsp enable -app asup,ems
When OCSP is enabled, the application receives one of the following responses:
Good - the certificate is valid and communication proceeds.
Revoked - the certificate is permanently deemed as not trustworthy by its issuing Certificate Authority and communication fails to proceed.
Unknown - the server does not have any status information about the certificate and communication fails to proceed.
OCSP server information is missing in the certificate - the server acts as if OCSP is disabled and continues with TLS communication, but no status check occurs.
No response from OCSP server - the application fails to proceed.
To enable or disable OCSP certificate status checks for all applications using TLS communications, use the appropriate command.
If you want OCSP certificate status checks for all applications to be… Use the command… Enabled
-app all
Disabled
-app all
When enabled, all applications receive a signed response signifying that the specified certificate is good, revoked, or unknown. In the case of a revoked certificate, the application will fail to proceed. If the application fails to receive a response from the OCSP server or if the server is unreachable, the application will fail to proceed.
Use the
security config ocsp show
command to display all the applications that support OCSP and their support status.cluster::*> security config ocsp show Application OCSP Enabled? -------------------- --------------------- autosupport false audit_log false fabricpool false ems false kmip false ldap_ad true ldap_nis_namemap true ssh true 8 entries were displayed.
