Verify the monitoring of cluster and management network switches
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
The cluster switch health monitor automatically attempts to monitor the switches that it discovers; however, monitoring might not happen automatically if the switches are not configured correctly. You should verify that the health monitor is properly configured to monitor your switches.
To identify the switches that the cluster switch health monitor discovered, enter the following command:
ONTAP 9.8 and latersystem switch ethernet show
ONTAP 9.7 and earliersystem cluster-switch show
If the
Model
column displays the valueOTHER
, then ONTAP cannot monitor the switch. ONTAP sets the value toOTHER
if a switch that it automatically discovers is not supported for health monitoring.If a switch does not display in the command output, you must configure discovery of the switch.
Upgrade to the latest supported switch software and reference the configuration file (RCF) from the NetApp Support Site.
The community string in the switch's RCF must match the community string that the health monitor is configured to use. By default, the health monitor uses the community string
cshm1!
.At this time, the health monitor only supports SNMPv2.
If you need to change information about a switch that the cluster monitors, you can modify the community string that the health monitor uses by using the following command:
ONTAP 9.8 and latersystem switch ethernet modify
ONTAP 9.7 and earliersystem cluster-switch modify
Verify that the switch's management port is connected to the management network.
This connection is required to perform SNMP queries.
