Availability of volumes and tape devices for backup and restore on different LIF types
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
You can configure a backup application to establish an NDMP control connection on any of the LIF types in a cluster. In the storage virtual machine (SVM)-scoped NDMP mode, you can determine the availability of volumes and tape devices for backup and restore operations depending upon these LIF types and the status of the CAB extension.
The following tables show the availability of volumes and tape devices for NDMP control connection LIF types and the status of the CAB extension:
Availability of volumes and tape devices when CAB extension is not supported by the backup application
NDMP control connection LIF type | Volumes available for backup or restore | Tape devices available for backup or restore |
Node-management LIF |
All volumes hosted by a node |
Tape devices connected to the node hosting the node-management LIF |
Data LIF |
Only volumes that belong to the SVM hosted by a node that hosts the data LIF |
None |
Cluster-management LIF |
All volumes hosted by a node that hosts the cluster-management LIF |
None |
Intercluster LIF |
All volumes hosted by a node that hosts the intercluster LIF |
Tape devices connected to the node hosting the intercluster LIF |
Availability of volumes and tape devices when CAB extension is supported by the backup application
Data LIF |
All volumes that belong to the SVM that hosts the data LIF |
None |
All volumes in the cluster |
All tape devices in the cluster |
Intercluster LIF |
