Commands for managing SVM-scoped NDMP mode
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You can use the vserver services ndmp
commands to manage NDMP on each storage virtual machine (SVM, formerly known as Vserver).
If you want to… | Use this command… | ||
Enable NDMP service |
Disable NDMP service |
Display NDMP configuration |
Modify NDMP configuration |
Display default NDMP version |
Display all NDMP sessions |
Display detailed information about all NDMP sessions |
Terminate a specified NDMP session |
Terminate all NDMP sessions |
Generate the NDMP password |
Display NDMP extension status |
This command is available at the advanced privilege level. |
Modify (enable or disable) NDMP extension status |
Start logging for the specified NDMP session |
Stop logging for the specified NDMP session |
For more information about these commands, see the man pages for the vserver services ndmp
commands.
