Could not initialize media
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
Message
Cause
You might get this error for one of the following reasons:
The tape drive used for the backup is corrupt or damaged.
The tape does not contain the complete backup or is corrupt.
The maximum number of active local tape I/O threads is currently in use.
You can have a maximum of 16 active local tape drives.
Corrective action
If the tape drive is corrupt or damaged, retry the operation with a valid tape drive.
If the tape does not contain the complete backup or is corrupt, you cannot perform the restore operation.
If tape resources are not available, wait for some of the backup or restore jobs to finish and then retry the operation.
