Failed to initialize tape
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Your file is ready
Message
Cause
You might get this error message for one of the following reasons:
The backup image is not of SMTape.
The tape blocking factor specified is incorrect.
The tape is corrupt or damaged.
The wrong tape is loaded for restore.
Corrective action
If the backup image is not of SMTape, retry the operation with a tape that has SMTape backup.
If the blocking factor is incorrect, specify the correct blocking factor and retry the operation.
If the tape is corrupt, you cannot perform the restore operation.
If the wrong tape is loaded, retry the operation with the correct tape.
