Manage node-scoped NDMP mode for FlexVol volumes overview
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
You can manage NDMP at the node level by using NDMP options and commands. You can modify the NDMP options by using the options
command. You must use NDMP-specific credentials to access a storage system to perform tape backup and restore operations.
For more information about the options
command, see the man pages.
Related information
