Tape record size is too small. Try a larger size.
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
Your file is ready
Message
Cause
The blocking factor specified for the restore operation is smaller than the blocking factor that was used during the backup.
Corrective action
Use the same blocking factor that was specified during the backup.
