How SMTape works with storage failover and ARL operations
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
Before you perform SMTape backup or restore operations, you should understand how these operations work with storage failover (takeover and giveback) or aggregate relocation (ARL) operation. The -override-vetoes
option determines the behavior of SMTape engine during a storage failover or ARL operation.
When an SMTape backup or restore operation is running and the -override-vetoes
option is set to false
, a user-initiated storage failover or ARL operation is stopped and the backup or restore operation complete. If the backup application supports CAB extension, then you can continue performing incremental SMTape backup and restore operations without reconfiguring backup policies. However, if the –override-vetoes
option is set to true
, then the storage failover or ARL operation is continued and the SMTape backup or restore operation is aborted.
