Tape write error
  • Message
    Tape write error - The previous tape had less than the required minimum capacity, size MB, for this tape operation, The operation should be restarted from the beginning
  • Cause
    The tape capacity is insufficient to contain the backup data.
  • Corrective action
    Use tapes with larger capacity and retry the backup job.
