Add hosts and install SnapCenter plug-in for Oracle database
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
You can use the Add Host page to add hosts, and then install the SnapCenter Plug-ins Package for Linux or SnapCenter Plug-ins Package for AIX. The plug-ins are automatically installed on the remote hosts.
You can add a host and install plug-in packages either for an individual host or for a cluster. If you are installing the plug-in on a cluster (Oracle RAC), the plug-in is installed on all the nodes of the cluster. For Oracle RAC One Node, you should install the plug-in on both active and passive nodes.
In the left navigation pane, click Hosts.
Verify that the Managed Hosts tab is selected.
Click Add.
In the Hosts page, perform the following actions:
In the Host Type field, select the host type.
In the Host name field, enter the fully qualified domain name (FQDN) or the IP address of the host.
In the Credentials field, enter the credential that you created.
In the Select Plug-ins to Install section, select the plug-ins to install.
(Optional) Click More Options and specify the details.
Click Submit.
Verify the fingerprint, and then click Confirm and Submit.
In a cluster setup, you should verify the fingerprint of each of the nodes in the cluster.
Monitor the installation progress.
